[gdal-dev] Re: [SoC] GDAL WKTRaster weekly report #9
Jorge Arévalo jorge.arevalo at gmail.com
Sun Aug 2 09:33:42 EDT 2009
Hello,
2009/8/2 Mateusz Loskot <mateusz at loskot.net>:
> Jorge Arévalo wrote:
>> When I create an overview (a children dataset), its properties are
>> the same properties of the general dataset (his parent), apart from
>> pixel size, table name and column_name, of course. The problem
>> appears when sharing the PGconn object.
>> My code looks like this:
>> poDS->overview[i]->hPGconn = poDS->hPGconn
>> If each dataset's destructor (from the general one and from the
>> overviews) calls PQfinish over the same object, I get a segmentation
>> fault after the first time, of course. So, I have 2 options: - Detect
>> when a connection object has been freed, and perform only one call.
>> How should I do this?
> If I understand it correctly, the problem can be summarised in some
> kind of pseudo-code as follows:
> struct Overview
>   PGconn* c;
>   Overview(PGconn* c) : c(c) {}
>   ~Overview() { PQfinish(c); }
> struct Dataset
>   PGconn* c;
>   Dataset(char const* connstr) { /*connect to pgsql*/ }
>   ~Dataset() {  PQfinish(c) ; c = 0; }
>   Overview get_overview() { return Overview(c); }
>   Overview ov;
>      Dataset d(...); // connect
>      ov = d.get_overview(); // side-effect: share connection
>   }  // Dataset dctor calls PQfinish
>   // Problem #1: Overview's connection no longer valid
> } // Problem #2: Overview dctor tries to close and fails
> Note: Overview here may be a subdataset, no difference between the two
> for the problem analysis.
Yes, the problem looks like that.
> Assuming this example reproduces the problem correctly, then
> there is no way to detect in Overview's dctor that
> connection is still valid.
Ok, but maybe the Even's idea of a boolean var set to TRUE in dataset
and to FALSE in overviews could be a good way to simulate this
situation.
> After Dataset dctor is called, the c pointer in Overview is a dangling
> pointer which stores an address in memory, but that address no longer
> identifies PGconn object.
Yes, that's exactly the problem. The memory address is still
allocated, but the content it's not a PGconn.
>> - Don't share the PGconn object. Should I declare a static PGconn
>> pointer?
> It would work just in the opposite direction - such static pointer would
> be shared. Concept of static object == concept of global object.
> They are used to implement shared resource, though in a weak and
> primitive way.
Yes, ok. I realized on a static object is a "shared" object, in the
sense of it's a global object. Bad words using, sorry.
>> What is the best approach?
> First, you have to identify if lifetime of Dataset and Overview (or
> Subdataset) is predictable - can Overview live longer than Dataset or
> lifetime of Dataset always exceeds lifetime of Overview object.
> 1. The Dataset always life longer is the simplest case, simply close
> connection only from Dataset and don't close it from Overview.
> In other words, Overview's connection is a weak reference [1] to
> connection in Dataset - meaning, Dataset is the only owner of connection.
Yes, that's the situation. I'll finish the connection only from the
dataset, using the boolean var Even suggested, I think.
> [1] http://en.wikipedia.org/wiki/Weak_reference
> 2. However, if Overview object can live longer than Dataset
> or moreover, you are not able to determine/predict what's
> possible lifetime of Dataset and Overview, then IMHO the best
> approach is to make PGconn a real shared object between Dataset
> and Overview.
> The simplest implementation is to use shared_ptr<T> from
> std::tr1 (in GCC 4.3+ or Visual C++ 9.0+) or from Boost libraries.
> However, I presume these are forbidden in GDAL, so you'd need to provide
> some minimal implementation of reference counting pattern on your own.
> Scott Meyers' example may be helpful:
> http://www.aristeia.com/BookErrata/M29Source.html
Thanks for the links (added to delicious :-)) and for your analysis
and solutions.
Best regards,
Jorge
> Best regards,
> Mateusz Loskot, http://mateusz.loskot.net
> Charter Member of OSGeo, http://osgeo.org
