[gdal-dev] Area intersection
Giacomo Piva
piva at meeo.it
Tue Aug 4 09:52:16 EDT 2009
Hi Bill,
First of all, thanks for your reply.
It seems ti be what I'm looking for, but unfortunately I have some
problems with documentation.
In OGRGeometry class I foud this two methods:
OGRGeometry::Intersects
OGRGeometry::Intersection
As I said I'm working to a C application, so I shall use these functions:
OGR_G_Intersects()
OGR_G_Intersection()
But I found a reference only for the OGR_G_Intersects() function...
Furthermore, I cannot understand HOW to create two geometry from a
geo-referenced image.
Someone can help me?
> Check out OGRGeometry for the intersection related methods:
> http://www.gdal.org/ogr/classOGRGeometry.html
> -----Original Message-----
> From: gdal-dev-bounces at lists.osgeo.org
> [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Giacomo Piva
> Sent: Monday, August 03, 2009 3:22 AM
> To: gdal-dev at lists.osgeo.org
> Subject: [gdal-dev] Area intersection
> Hi All,
> I'm trying to get georeferencing information from a GeoTIFF file in
> order to find if there is an intersection between two images.
> Does someone can help me in this stuff?
> What should i do?
> Thanks.
Giacomo Piva
MEEO S.r.l.
Via Saragat 9
I-44122 Ferrara, Italy
Tel: +39 0532 1861501
Fax: +39 0532 1861637
http://www.meeo.it
"ATTENZIONE:le informazioni contenute in questo messaggio sono
da considerarsi confidenziali ed il loro utilizzo è riservato unicamente
al destinatario sopra indicato. Chi dovesse ricevere questo messaggio
per errore è tenuto ad informare il mittente ed a rimuoverlo
definitivamente da ogni supporto elettronico o cartaceo."
"WARNING:This message contains confidential and/or proprietary
information which may be subject to privilege or immunity and which
is intended for use of its addressee only. Should you receive this
message in error, you are kindly requested to inform the sender and
to definitively remove it from any paper or electronic format."
