[gdal-dev] Re: SDE connection string problem with 1.6.1?
bartvde at osgis.nl
bartvde at osgis.nl
Fri Aug 7 05:17:36 EDT 2009
An update on this issue. This is a bug and is still present in 1.6.2
unfortunately.
The problem is in ogrsdedatasource.cpp, where the else clause which lists
all spatial tables was moved down, so it now corresponds to a different if
clause.
old code:
if ( CSLCount( papszTokens ) == 6 && *papszTokens[5] != '\0' )
OpenSpatialTable( papszTokens[5] );
else
EnumerateSpatialTables();
new code:
else if ( CSLCount( papszTokens ) == 8 && *papszTokens[7] != '\0' )
else
CPLDebug("OGR_SDE", "Setting version to SDE.DEFAULT");
nSDEErr = SetVersionState("SDE.DEFAULT");
if (!nSDEErr)
// We've already set the error
CSLDestroy( papszTokens );
return FALSE;
Best regards,
Bart
> Hi list,
> it seems the layer part of an SDE connection string is not picked up
> anymore. We're using GDAL 1.6.1. Did anybody else experience this?
> E.g.:
> ogrinfo
> SDE:geodatabase.ad.rws.nl,5151,5151,RWS_LEZEN,****,WEGEN.WEGEN_NWB_LIGHT
> lists all tables and not only the one specified.
> TIA.
> Best regards,
> Bart
