[gdal-dev] Overriding IRasterIO in class derived from
GDALRasterBand
Even Rouault
even.rouault at mines-paris.org
Fri Aug 7 16:31:24 EDT 2009
----- Original Message -----
To: "Tamas Szekeres" <szekerest at gmail.com>
Cc: "gdal-dev" <gdal-dev at lists.osgeo.org>
Sent: Friday, August 07, 2009 7:43 PM
Subject: Re: [gdal-dev] Overriding IRasterIO in class derived from
GDALRasterBand
>OK, I commented this part during tests, -1 for me. The assertion
>disappeared. Many thanks.
>And about the time, it's only when executing gdalinfo with options
>"-mm -stats -checksum". Takes about 35 seconds, with this image
>http://download.osgeo.org/gdal/data/gtiff/utm.tif and one overview of
>factor 2 (50% of size in both dimensions). I suppose is normal...
This looks quite slow to me for a modest 512x512 raster.
"gdalinfo -mm -stats -checksum utm.tif" takes less than one second.
You should try to profile what is slow exactly : the DB request (server-side
performance issue ?), the decoding of the result, ...
>So, you suggest to copy the block data into the buffer without calling
>base implementation of IRasterIO, do you? This implies take care of
>the endianess and pixel size "by hand".
Implementing yourself all the cases of IRasterIO will be complicated. Just
look at GDALRasterBand::IRasterIO in rasterio.cpp. If you really want to
implement it, I'd advise you to only concentrate first on a few common
cases, like when the output buffer size is equal to the source buffer size
(nXSize == nBufXSize && nYSize == nBufYSize). For other cases, default to
the base implementation.
>Best regards,
>Jorge
> Best regards,
> Tamas
> 2009/8/7 Jorge Arévalo <jorge.arevalo at gmail.com>
>> Hello,
>> Context: GDAL WKT Raster driver
>> In my class derived from GDALRasterBand, I've overrided the methods:
>> - IReadBlock: Fetch a block from database
>> - IRasterIO: Should fetch several blocks, that cover an area, and add
>> them to papoBlocks (cache). The idea is to avoid rounds in the server
>> AFAIK, the base IRasterIO implementation (in GDALRasterBand), tries to
>> fetch the block from the cache. If the block isn't in the cache, then
>> call to IReadBlock. So, the normal way to read blocks in any GDAL
>> driver should be IRasterIO --> IReadBlock
>> Then, If I override IRasterIO in my driver RasterBand's class, I
>> should fetch several blocks in one round and call GetLockedBlockRef to
>> add these blocks to the cache. After this, call the base
>> implementation of IRasterIO (in GDALRasterBand) to do its work (see
>> previous point).
>> Is it correct? I have problems with my IRasterIO implementation,
>> because it takes a long time executing until this fail:
>> ERROR 7: Assertion `nLockCount == 0' failed
>> in file `gdalrasterblock.cpp', line 228
>> Is there any mistake in this approach? If not, I suppose I had to
>> debug my queries, but I'd like to rule our wrong concepts first.
>> Many thanks in advance.
>> Best regards,
>> Jorge
>> gdal-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
