[gdal-dev] With 1.6.2,still can't read ArcInfo binary grids:
GDAL Error 3:Attempt to read past EOF
inC:\Temp\GeoEcoTemp_Jason\tmpopx_s3\projected0a/../info/arc.dir.
Roger Bivand
Roger.Bivand at nhh.no
Sat Aug 8 09:21:03 EDT 2009
On Sat, 8 Aug 2009, Even Rouault wrote:
> ----- Original Message ----- From: Jason Roberts
> To: gdal-dev at lists.osgeo.org
> Cc: 'Roger Bivand'
> Sent: Saturday, August 08, 2009 12:05 AM
> Subject: [gdal-dev] With 1.6.2,still can't read ArcInfo binary grids: GDAL
>> Hi all,
>> I am using rgdal to read ArcInfo binary grids produced by ArcGIS. The
>> latest public version of rgdal, which binds with GDAL 1.6.1, fails with the
>> error message in the subject line of this email. I reported this a couple
>> of weeks ago in
>> http://lists.osgeo.org/pipermail/gdal-dev/2009-July/021369.html.
>> Today, the rgdal developer (Roger Bivand) provided me with an rgdal built
>> against the 1.6.2 release candidate issued 31 July. The problem still
>> exists.
> OK, I've looked more closely at
> http://rgdal.cvs.sourceforge.net/viewvc/rgdal/rgdal/src/gdal-bindings.cpp?revision=1.32&view=markup
> and I see RGDAL defines its own error handler for GDAL errors (around lines
> 114-134). So the fix pushed in 1.6.2 that solves the issue for Python and
> other bindings languages will not help for the RGDAL case as the error() call
> probably causes a R exception to be thrown. As I've no knowledge of R, it is
> just wild guessing.
Even, Jason,
Thanks, this looks helpful. I'll try to see how it fits into the error
handler put in place from the R side. An R error() unwinds all the way up
the call trace in C/C++ through to the R code; there is a warning() that
could be used for non-fatal GDAL errors (though it isn't obvious which
ones shouldn't be fatal, and since we're in a running R session, we cannot
really allow anything not safe to persist (like a handle to a dataset not
opened properly).
Jason, please send me off-list an example offending file (or link if big)
so that I'll know when I'm making progress.
Roger
> RGDAL_OpenDataset() could be modified so that its own error handler is not
> used during GDALOpen. Something like this might do it :
> CPLErrorReset();
> CPLPushErrorHandler(CPLDefaultErrorHandler);
> GDALDataset *pDataset = (GDALDataset *) GDALOpen(fn, RWFlag);
> CPLPopErrorHandler();
> // Similarly to SWIG bindings, the following lines will cause
> RGDAL_OpenDataset() to fail on - unclearred - errors even if pDataset is not
> NULL.
> // They could also be just removed. While pDataset != NULL, there's some hope
> CPLErr eclass = CPLGetLastErrorType();
> if (pDataset != NULL && eclass == CE_Failure)
> GDALClose(pDataset);
> pDataset = NULL;
> __errorHandler(eclass, CPLGetLastErrorNo(), CPLGetLastErrorMsg());
> if (pDataset == NULL)
> error("Could not open file: %s\n", filename);
> Note this is uncompiled & untested, but that should avoid similar situations
> in other drivers (non fatal errors triggered during dataset opening and
> cleared by CPLErrorReset() ) to occur .
>> The problem had apparently been seen before. My original email prompted a
>> review of the issue, including mention of it being tracked in tickets
>> #2447 and #3031. Evan made some checkins on 22 July that I thought would
>> result in this being fixed in both the trunk and the next release of 1.6
>> (which would be 1.6.2). But I guess I did not fully understand it, and I
>> missed the fact that neither of these issues appeared in Howard's 31 July
>> release candidate email.
> The tickets are not mentionned in Howard's email because the fix is only
> partial and the tickets still open.
>> So: is there any chance the GDAL team can fix this in either 1.6.2 or, if
>> it is now too late, 1.6.3?
>> It may be that this fell off the radar because the severity of the tickets
>> (for example, #3031 is minor), or because there was a suggested workaround
>> that users could simply rename the "info" directory to prevent GDAL from
>> failing. Well the issue is indeed severe if you are an ArcGIS user. In my
>> case, the rasters were produced by ArcGIS 9.3.1. Presumably ESRI is
>> generating the rasters correctly. The workaround of renaming the info
>> directory is not a good idea. That renders all of the rasters in a
>> directory inaccessible to ArcGIS. It is a major corruption of the ArcInfo
>> binary grid
>> format to do so. I'm not sure why it was suggested in the first place, but
>> it is a very bad idea.
> Eh! workarounds are workarounds and generally not very elegant. It enables
> GDAL to avoids reading the VAT table, but if ArcGIS doesn't like it, that's
> another story... The advantage with renaming is that you can undo it when
> necessary... Anyway, you're free of ignoring it if you don't like it.
>> I'm sorry for not staying on top of this issue and somehow missing that it
>> was not put into 1.6.2 and that the workaround is such as bad idea. In any
>> case, could you please consider fixing this in 1.6 soon? I can provide
>> example data if needed.
> #3031 has already a link to sample data that triggers the error message. You
> just need to find and convince someone that has time and knowledge of the AVC
> driver.
>> Thanks,
>> Jason
> gdal-dev mailing list
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
