[gdal-dev] Expanding a palette image to 3 bands
Frank Warmerdam
warmerdam at pobox.com
Fri Aug 14 09:52:56 EDT 2009
On Fri, Aug 14, 2009 at 9:21 AM, Henneke, Amanda
M<amanda.m.henneke at boeing.com> wrote:
> Hello all-
> I have a need to expand a 1 band palette tif file into a 3 band (rgb) tif file. I have found that gdal_translate -expand rgb will do this from the command line, but I was wondering if there was some way to do this within C# using the GDAL bindings? I notice there is a ColorTable object and PaletteInterpretation object, but I haven't figured out yet (or seen anything online) about how to use these to expand the image.
Amanda,
You could skim the gdal_translate code to see how -expand rgb
works, but unfortunately it depends on access to VRT classes
that are not directly callable from C# or other swig bindings. However,
you can compose the corresponding VRT XML directly in C# and
then "open" that VRT XML as a dataset that will have the expanded
bands. This VRT dataset can then be passed to a CreateCopy() to
write out the expanded result.
I have attached the results of "gdal_translate -of VRT -expand rgb" on
a dataset as an example of the corresponding XML.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090814/a96e8a9a/out.obj
