[gdal-dev] Converting to J2K
Greg Coats
gregcoats at mac.com
Tue Aug 18 12:35:50 EDT 2009
According to http://www.gdal.org/formats_list.html , GDAL supports
four flavors of JPEG2000, four different implementations of wavelet
compression, based on JasPer, Kakadu, ECW, and MrSID. Two of these
four are available to me
gdal_translate | grep 2000
JP2KAK: JPEG-2000 (based on Kakadu)
JPEG2000: JPEG-2000 part 1 (ISO/IEC 15444-1)
Which of these four are available to you?
When creating and writing a JPEG2000 file, use -of to specify which of
the available flavors you want GDAL to use.
/usr/bin/time gdal_translate -of JPEG2000 18stj940125.tif
18stj940125_gdalV162_of_JPEG200.jp2
Input file size is 5000, 5000
0...10...20...30...40...50...60...70...80...90...100 - done.
24.27 real 20.91 user 2.47 sys
/usr/bin/time gdal_translate -of JP2KAK 18stj940125.tif
18stj940125_gdalV162_of_JP2KAK.jp2
15.75 real 15.06 user 0.30 sys
Greg
On Aug 18, 2009, at 11:14 AM, Smart, Gary wrote:
> I have tried just about all the standard J2K extensions – none
> appear to work.
> This is the output from...
> gdal_translate -of JPEG2000 image.ntf image.jp2
> Input file size is 4008, 2672
> ERROR 4: `image.jp2' not recognised as a supported file format.
> The 0..10... bit happens absurdly quickly (as if it does nothing
> useful)
> The ERROR is (I think) perhaps generated by an automatic gdalinfo
> directly after the translate.
> Certainly, a gdalinfo on the created file returns an almost
> identical error.
> I can convert the ntf file into a geotiff OK. But then, if I try
> and convert the geotiff to jp2 – it fails – giving exactly the same
> symptoms. Is there some sort of JPEG2000 library I have to
> specifically load or something?
> From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org
> ] On Behalf Of Greg Coats
> Sent: 18 August 2009 15:44
> To: Smart, Gary
> Cc: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] Converting to J2K
> $ gdal_translate --version
> GDAL 1.6.2, released 2009/07/31
> $ gdal_translate -of JPEG2000 18stj940125.tif 18stj940125.jp2
> FYI The convention for JPEG2000 image files is to use the
> extension .jp2.
> Greg
> On Aug 18, 2009, at 4:13 AM, Smart, Gary wrote:
> I am trying ‘gdal_translate –of JPEG2000 thingy.ntf thingy.j2k’
> but GDAL complains that it doesn’t understand the format thingy.j2k
> I think its getting the arguments confused. What am I doing wrong?
> gdal-dev mailing list
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090818/1263809f/attachment.html
