[gdal-dev] regarding GDALDriver::Create
Frank Warmerdam
warmerdam at pobox.com
Wed Aug 19 10:17:27 EDT 2009
Srikanth wrote:
> Hi ,
> Thanks for the mail Frank.
> The problem is rightly pointed. In my case the dataset (poDataset) is
> not getting created at times (parameters being the same) . I have
> checked thoroughly everything related to this, but did not find any
> either solution or problem.
> I would appreciate if you can assist me solving this issue.
Srikanth,
After a failed Create() operation you can call CPLGetLastErrorMsg() and display
the resulting string. It should give some idea of what is going wrong.
In a normal console application you should also see this message emitted in
the console (stderr) automatically.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
