[gdal-dev] Re: Status of TMS minidriver in gdal_wms
Roger André
randre at gmail.com
Thu Aug 20 01:08:43 EDT 2009
I was able to get this to work using the patch checked in from the Toronto
code sprint. However, I still have questions. I would like to take
advantage of the fact that I already have pre-rendered tiles in my
TileCache, but it seems that MapServer is still having to render all of the
requests that I'm making through the WMS service. How can I use my
pre-existing TileCache tiles as the data source? Do I need to match the
projection that they are created in when I make the request? Do I need to
set resolution levels in the GDAL_WMS file? I followed the syntax in the
OSM GDAL_WMS sample to make the requests work.
Thanks,
Roger
On Wed, Aug 19, 2009 at 3:18 PM, Roger André <randre at gmail.com> wrote:
> Hi All,
> I'd like to use GDAL to access tiles that have been generated by
> TileCache. It appears this should be possible in GDAL 1.7 via the TMS
> service. I *think* the example at
> http://www.gdal.org/frmt_wms_openstreetmap_tms.xml shows this.
> I'd appreciate it if someone could clarify whether my expectations are
> reasonable regarding this, and whether this functionality can be enabled in
> a pre-1.7 version of GDAL.
> Thanks,
> Roger
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090819/044c6d4a/attachment.html
