[gdal-dev] Re: Strange things with gdalwarp ...
Greg Coats
gregcoats at mac.com
Sat Aug 22 12:29:47 EDT 2009
On Aug 22, 2009, at 4:51 AM, Hermann Peifer wrote:
> Just to repeat my earlier observations: over the last days, I tried
> with all kinds of -wm and GDAL_CACHEMAX settings, and also added
> the options TILED=YES and SKIP_NOSOURCE=YES. I haven't documented
> the performance changes systematically, but my overall impression
> was that the changes were rather small. I also tried -multi on my
> dual processor machine, but I ended up with a fatal error.
In January 2009, working with GDAL version 1.6.0, I did some testing
and documenting of the effect of GDAL_CACHEMAX. Using as input an
uncompressed GeoTif 15,000 x 15,000 x 3 = 675 MB, organized into 1024
x 1024 tiles, I found that using gdal_translate to convert this
GeoTif to a GeoJP2 with the default --config GDAL_CACHEMAX 40 took
10473 sec (= 175 minutes), but increasing GDAL_CACHEMAX by only 12.5%
to --config GDAL_CACHEMAX 45 the processing took only 166 sec (= 2.7
minutes), which is 63 times faster! Further tests showed that
increasing --config GDAL_CACHEMAX to values greater than 45 (up to
1800) did not effect processing time. Greg
GDAL 1.6.0, released 2008/12/04
Input GeoTif 15,000 x 15,000 x 3 = 675 MB
gdal_translate -of JP2KAK -co QUALITY=10 --config GDAL_CACHEMAX
0040 10473.14 sec
0041 10326.75 sec
0042 10492.85 sec
0043 7081.57 sec
0044 3503.33 sec
0045 166.23 sec
0050 166.31 sec
0055 165.89 sec
0060 165.78 sec
0080 165.48 sec
0100 166.53 sec
0125 165.59 sec
0150 165.72 sec
0200 165.65 sec
0250 166.58 sec
0300 166.13 sec
0350 166.59 sec
0400 166.06 sec
0600 166.00 sec
0800 165.10 sec
1000 165.25 sec
1200 165.94 sec
1400 165.43 sec
1600 165.56 sec
1800 166.31 sec
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090822/de771245/attachment.html
