[gdal-dev] Re: Strange things with gdalwarp ...
    Adam Nowacki
    nowak at xpam.de
    Mon Aug 24 08:41:18 EDT 2009
You can test with http://pastebin.com/m45e46f53
Also remember to use -wo SKIP_NOSOURCE=YES
Hermann Peifer wrote:
> Adam Nowacki wrote:
>> Some rather counterintuitive gdalwarp behavior: the bigger
>> dfWarpMemoryLimit (-wm setting) the more cpu time will be wasted on
>> warping not existing pixels. Why? Warping begins with the destination
>> window size of entire output image size. If this size is larger than
>> dfWarpMemoryLimit it is split in half along the longest axis and any
>> half that doesn't contain the currently processed source file is
>> discarded. With large dfWarpMemoryLimit this subdivision process will
>> stop early with still large portions of out of source image pixels.
> Given Adam's explanations above, could someone tell me if my below
> assumptions are correct? Thanks.
> Just to repeat, the input files are ASTER GTiffs in WGS84, 3601x3601
> pixels each. The output is a single mosaic of all tiles, a 100m GTiff,
> in LAEA projection
> gdalwarp -wm 300 --config GDAL_CACHEMAX 300 --debug on ... reports:
> Src=0,0,3601x3601 Dst=36375,31125,12125x10375
> I understand this as follows: the source image of 3601x3601 pixels is
> read as one chunk (which after reprojection and resampling should be
> around 800x1100 pixels). However, 12125x10375 pixels are actually
> written to the output file. So 99.5% of the destination window must be
> completely unrelated to my input image.
> If I counter-intuitively reduce the memory limit to, say: 40 MB and
> leave anything else unchanged, then gdalwarp behaviour changes to
> Src=0,0,3601x3601 Dst=45468,38906,1516x2594
> This tells me that the destination window is much smaller and gdalwarp
> will not waste time to write out so many irrelevant pixels, correct?
> Perhaps gdalwarp should not only test if the destination window fits
> into memory, but also check what would be the minimum destination window
> for warping the input image. This could speed up the mosaicing of small
> tiles into a bigger output file.
> Hermann
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
