[gdal-dev] Extracting band from raster stack & ENVI Header question
Markus Reinhold
markus.reinhold at uni-jena.de
Mon Aug 24 18:06:39 EDT 2009
Hejhej,
please allow me two short questions:
1) Using the GDAL Python bindings I currently need to extract a single
band from a raster stack and save it in a different format, i.e. ENVI.
To achieve this my processing includes
(a) analysis of the source dataset and desired band (width, height,
pixel size, data type, geotransform),
(b) creation of a temporary in-memory dataset with one band (using
Driver.Create()) that is identical with the desired source band except
that it is all black and
(c) creation of a copy of the temporary dataset (using
Driver.CreateCopy()) and setting it according to the original data
(using RasterBand.ReadAsArray() and RasterBand.WriteArray()).
I found the second step necessary as for ENVI data it is only possible
to create datasets using Driver.CreateCopy() for which a template is
needed - hence the temporary single band dataset... My solution works, I
find it a bit awkward though. Is there a simpler way to do this?
2) Another question concerning the creation of ENVI datasets with GDAL.
I had been under the impression that *map info* strings for the ENVI
header weren't created when copying another dataset. Now I have found
that when the dataset is in a certain projection and coordinate system,
i.e. UTM/WGS84 in my case, this is done after all. Is there any rule for
which configurations GDAL is able to create a *map info*-section in the
ENVI header?
Thank you very much in advance.
Regards,
Markus
Dipl.-Kartograph Markus Reinhold
Chair of Geoinformatics, Geohydrology and Modeling
Friedrich-Schiller-University Jena
Löbdergraben 32
D - 07743 Jena
Germany
Phone.: (+49)(0)3641 / 9 488 65
E-Mail: markus.reinhold at uni-jena.de
