[Gdal-dev] Problem with compiling 1.6.2 in VC6.0
Frank Warmerdam
warmerdam at pobox.com
Wed Aug 26 11:08:32 EDT 2009
subramaniam wrote:
> Dear All
> I have downloaded 1.6.2 source code and tried to compile in windows 32bit
> with Microsoft Visual studio 6.0 version. I getting error after the
> generation of the gdal-i.lib and other library files. So i am not getting
> the corresponding executive file *.dll. I need help for solving this
> problem. Thanks in advance for thr help.
> With warm regards
> S.Subramaniam
S.
The project is no longer actively trying to support VC6 which is ... pretty
old now. But if you actually quote the error you are encountering we might
be able to provide some advice. I imagine GDAL can be built with VC6 with
some fiddling and hacking.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
