[gdal-dev] OGR random read optimization?
Even Rouault even.rouault at mines-paris.org
Tue Dec 1 17:41:10 EST 2009
Ray,
The idea is interesting but unfortunately, I don't see how this can be
implemented in a generic way in current OGRLayer. The root of the
problem is that OGRLayer doesn't track the current index because
GetNextFeature() is a virtual method overriden by each driver. The
nicest way your idea could be implemented would be to have instead a
virtual IGetNextFeature() method which would be the one overriden by
drivers (and do the job of current GetNextFeature()) but called by non
virtual OGRLayer::GetNextFeature(). The latter method could keep track
of the current index and store it as a member of OGRLayer. This would be
a bit similar to RasterIO() / IRasterIO() that exists on the GDAL side.
The approach would also have the advantage to avoid that each driver's
GetNextFeature() has to deal with testing spatial and attribute filters.
Unfortunately, this would require changes in all OGR drivers, which
makes it probably not appropriate for any release in the GDAL/OGR 1.X
series. Maybe something for a GDAL/OGR 2.0 ;-) ?
In fact, this could be in theory introduced in a backward compatible way
if we :
1) Add a OGRLayer::IGetNextFeature() virtual method : Default
implementation in OGRLayer class : issue a CPLError and return NULL
2) Add a OGRLayer::IResetReading() virtual method : Default
3) Add a OGRLayer::ImplementsIGetNextFeatureAndIResetReading() virtual
method. Default implementation in OGRLayer class : return FALSE.
4) Change OGRLayer declaration so that GetNextFeature() and
ResetReading() are no longer pure virtual, but just virtual. Their
default implementation would call IGetNextFeature() and IResetReading()
5) Change OGRLayer::SetNextByIndex() default implementation so that it
does the optimization you suggest when
ImplementsIGetNextFeatureAndIResetReading() returns TRUE. Otherwise it
defaults to current code.
That approach would not require any code change in existing drivers. And
drivers interested in the new capability would just need to rename their
GetNextFeature() -> IGetNextFeature(), ResetReading() -> IResetReading()
and override ImplementsIGetNextFeatureAndIResetReading() to make it
return TRUE.
I'm wondering if it's worth the change. For true random access patterns,
even with your optimization, SetNextByIndex() will always be slow for
drivers that don't have a specialized fast implementation of it (average
complexity of O(n) by call). It can only bring performance gains if you
request increasing indices.
I'd note that currently efficient implementations of SetNextByIndex()
exist in Shapefile, MEM and GRASS drivers. GDAL/OGR 1.7.0dev has also
added implementation of it for PostgreSQL and VRT (for the latter, only
if the underlying layer has OLCFastSetNextByIndex capability).
Best regards,
Even
Ray Gardener a écrit :
> The OGRLayer::SetNextByIndex() function can be sped up by keeping
> track of the previously used index, and calling ResetReading() only if
> the new index is lesser than it. Otherwise, read forward and skip
> features by the difference of the new and old indices.
> For thread safety, the old index should be kept in a caller-level data
> structure which is passed in as an argument to SetNextByIndex.
> Ray
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
