[gdal-dev] /usr/lib/libexpat.so found when /usr/lib64/libexpat.so
needed
Roger Bivand
Roger.Bivand at nhh.no
Fri Dec 4 11:19:20 EST 2009
In trying to build GDAL 1.6.3 and 1.7.0 on an RHEL 5 64-bit box, I'm
seeing that libtool in linking is inserting -L/usr/lib
/usr/lib/libexpat.so and provoking:
/usr/lib/libexpat.so: could not read symbols: File in wrong format
collect2: ld returned 1 exit status
make[1]: *** [libgdal.la] Error 1
make[1]: Leaving directory `/home/rsb/topics/gdal/gdal'
make: *** [check-lib] Error 2
in the step after:
libtool: link: creating GNU ld script: .libs/libgdal.la.lnkscript
On the same box with the same:
./configure --with-netcdf=/usr/include/netcdf-3
1.6.2 now also fails, although it built when released.
I expect that the 32-bit /usr/lib/libexpat.so got installed to meet
another binary install dependency (GEOS ? netcdf ? among others ??), and I
cannot remove it without the other binaries going away. I've tried
incantations with --with-expat= without effect. Has anyone seen similar
behaviour and does anyone have a fix?
This hurts because this is my main development box, but I have to use a
distant 32-bit RHEL 5 box with very similar binary installs instead for
work now on the coming SAGA driver.
Best wishes,
Roger
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
