[gdal-dev] SWIG Version
Tamas Szekeres szekerest at gmail.com
Sun Dec 6 11:59:07 EST 2009
1.3.39 should be fine with the c# bindings as well.
I'm using this version for my regular builds since 2009 05.
Best regards,
Tamas
2009/12/6 Frank Warmerdam <warmerdam at pobox.com>
> Folks - particularly swig bindings maintainers,
> I have regenerated the swig bindings for python with swig 1.3.39 on
> www.gdal.org and committed them.  I used that version to be compatible
> with what Even used last time.  However, the scripts that building
> the perl and csharp bindings for the nightly snapshots are still using
> SWIG 1.3.36.
> Before GDAL 1.7 release, I'd like us to settle on a preferred version of
> SWIG and I will update this to be the one used for the nightly snapshots
> and that we would use at other times for building source distributions.
> Is SWIG 1.3.39 acceptable for all bindings maintainers?
> PS. SWIG 1.3.39 is built and installed in ~warmerdam/gdal-swig on
> www.gdal.org (aka xblade14).   SWIG 1.3.36 is in /usr/local/bin.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091206/0316bc7b/attachment.html
