Re: [gdal-dev] Python 3.X support added for GDAL Python bindings
Ivan Lucena
ivan.lucena at pmldnet.com
Sun Dec 6 18:35:56 EST 2009
Hi Even,
Is the Python 3.0 still compiled with VC71? I am asking that because I tried to build a GDAL-Python with VC9 (VS
2008 Express Edition) and it usually doesn't work since Python 2.5 was compiled with VC71 (VS 2003).
Regards,
Ivan
> -------Original Message-------
> From: Even Rouault <even.rouault at mines-paris.org>
> Subject: [gdal-dev] Python 3.X support added for GDAL Python bindings
> Sent: Dec 06 '09 15:43
> Folks,
> I've just added support for Python 3.X in trunk (
> http://trac.osgeo.org/gdal/ticket/3265 ). Compatibility with Python 2.X
> has been kept of course.
> The bindings are successfully regenerated and autotest suite passes with
> both Python 2.3, Python 2.6 and Python 3.1 (except a few OGR tests that
> involve non ASCII content that don't pass with Python 3.1)
> As this is a pretty massive change (159 files changed), broad testing
> would be appreciated to ensure that at least no regression was
> introduced when run against Python 2.X
> Best regards,
> Even
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
