[Gdal-dev] Import ESRI shpaefile (line) into exsiting Oracle
Spatial schema
Dejan Gregor
dejan.gregor at GMAIL.COM
Tue Dec 8 09:20:29 EST 2009
I was searching fro a good sample how I can import a file called
'LINE5001.shp' (linear feature class) into a predefined schema of an SDO
layer in 'USER1' schema into the 'LINE1' table? TNS name is 'ORCL'.
Geometry field is called 'GEOM' and the SRID for the SDO layer is set to the
value '5000000'. The schema owner 'USER1' has a password 'pwd'.
What would be syntax for the import of the line objects into Oracle through
OCI and OGR2OGR?
I have found a sample on the
ogr2ogr -f OCI OCI:user1/pwd at orcl LINE5001.shp ...?
Any help would be very much appreciated.
Dejan
__
Dejan Gregor, MSc
GISc Researcher and Consultant
http://www.linkedin.com/in/dgregor
View this message in context: http://n2.nabble.com/Import-ESRI-shpaefile-line-into-exsiting-Oracle-Spatial-schema-tp4132690p4132690.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
