[gdal-dev] Changing CURL options
Joel Odom
joelodom at gmail.com
Wed Dec 9 11:28:15 EST 2009
Is there a good way to change CURL options at run-time? We're using the
pre-built GDAL binaries, and I need to change the CURL behavior when I call
into GDAL from FalconView. Specifically, I want to disable SSL certificate
verification. Thanks for any help on this.
http://giscoder.blogspot.com/
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091209/7235c0a9/attachment.html
