[gdal-dev] merge two black/white image -> result only black
Even Rouault
even.rouault at mines-paris.org
Wed Dec 9 12:45:54 EST 2009
Jan,
I see 2 issues :
1) your 2 images have the same spatial extent ! So gdal_merge has
nothing to merge really... It will just copy the data from the second
image on top of the data from the first image I think.
2) the images have a color table. But by default, gdal_merge doesn't
copy it to the target file. You'd have to add the -pct option on the
command line for that.
Best regards,
Even
Jan Tappenbeck a écrit :
> hallo !
> i had two tif-image and want to merge them:
> d:\cad\FWTools2.4.6>gdalinfo c:\temp\geesthacht\586922g.tif
> Driver: GTiff/GeoTIFF
> Files: c:\temp\geesthacht\586922g.tif
> c:\temp\geesthacht\586922g.tfw
> Size is 8000, 8000
> Coordinate System is `'
> Origin = (3585999.875000000000000,5924000.125000000000000)
> Pixel Size = (0.250000000000000,-0.250000000000000)
> Metadata:
> TIFFTAG_SOFTWARE=IrfanView
> TIFFTAG_XRESOLUTION=508
> TIFFTAG_YRESOLUTION=508
> TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
> Image Structure Metadata:
> COMPRESSION=CCITTFAX4
> INTERLEAVE=BAND
> MINISWHITE=YES
> Corner Coordinates:
> Upper Left ( 3585999.875, 5924000.125)
> Lower Left ( 3585999.875, 5922000.125)
> Upper Right ( 3587999.875, 5924000.125)
> Lower Right ( 3587999.875, 5922000.125)
> Center ( 3586999.875, 5923000.125)
> Band 1 Block=8000x1 Type=Byte, ColorInterp=Palette
> NBITS=1
> Color Table (RGB with 2 entries)
> 0: 255,255,255,255
> 1: 0,0,0,255
> d:\cad\FWTools2.4.6>gdalinfo c:\temp\geesthacht\586922h.tif
> Files: c:\temp\geesthacht\586922h.tif
> c:\temp\geesthacht\586922h.tfw
> Size is 8000, 8000
> Metadata:
> INTERLEAVE=BAND
> MINISWHITE=YES
> Corner Coordinates:
> NBITS=1
> 0: 255,255,255,255
> 1: 0,0,0,255
> i merge with gdal_merge by following command:
> d:\cad\FWTools2.4.6>gdal_merge -v -o C:\temp\geesthacht\gh_test.tif
> -of GTiff -co COMPRESS=LZW c:\temp\geesthacht\586922g.tif
> but when i open the resultfile it is black-complete! !
> d:\cad\FWTools2.4.6>gdalinfo c:\temp\geesthacht\gh_test1.tif
> Files: c:\temp\geesthacht\gh_test1.tif
> Size is 8000, 8000
> COMPRESSION=LZW
> INTERLEAVE=BAND
> Corner Coordinates:
> Band 1 Block=8000x1 Type=Byte, ColorInterp=Gray
> can anybody tell me why ?????
> regards Jan :-)
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
