[gdal-dev] gdal-grass fail to build
Even Rouault
even.rouault at mines-paris.org
Wed Dec 9 15:16:24 EST 2009
I'm pretty sure that the gdal-grass-1.4.3 package is likely not recent
enough to be compatible with recent GRASS.
You probably need the version of the grass driver from the GDAL SVN
trunk where there were changes a few months ago to build against newer
GRASS.
Alfredo Alessandrini a écrit :
> Hi,
> The build failed when I try to compile gdal-grass.
> alfredo at astore:~/alfredo/grass_install/gdal-grass-1.4.3$ ./configure
> --with-gdal=/usr/local/bin/gdal-config
> --with-grass=/usr/local/grass-7.0.svn
> checking for gcc... gcc
> checking for C compiler default output file name... a.out
> checking whether the C compiler works... yes
> checking whether we are cross compiling... no
> checking for suffix of executables...
> checking for suffix of object files... o
> checking whether we are using the GNU C compiler... yes
> checking whether gcc accepts -g... yes
> checking for gcc option to accept ANSI C... none needed
> checking for g++... g++
> checking whether we are using the GNU C++ compiler... yes
> checking whether g++ accepts -g... yes
> checking for ranlib... ranlib
> checking for g++ -shared ... yes
> user supplied gdal-config (/usr/local/bin/gdal-config)
> using /usr/local/lib/gdalplugins as GDAL shared library autoload directory
> checking for G_asprintf in -lgrass_gis... no
> configure: error: --with-grass=/usr/local/grass-7.0.svn requested, but
> libraries not found! Perhaps you need to set LD_LIBRARY_PATH to
> include /usr/local/grass-7.0.svn/lib?
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
