[gdal-dev] 1.7.0 MSYS build broken in GPX
Roger Bivand Roger.Bivand at nhh.no
Thu Dec 10 04:25:31 EST 2009
I've probably missed something, but while 1.6.3 builds OK with EXPAT for
GPX on MSYS, 1.7.0 revision 18238 doesn't. The problem is in:
libtool: compile:  g++ -O2 -Wall -I.. -I../.. -I/usr/local/include
-I/home/s1155 /gdal_svn/gdal/port -I/home/s1155/gdal_svn/gdal/gcore
-I/home/s1155/gdal_svn/gdal/alg -I/home/s1155/gdal_svn/gdal/ogr
-I/home/s1155/gdal_svn/gdal/ogr/ogrsf_frmts -DOGR_ENABLED
-I/home/s1155/gdal_svn/gdal/port -DHAVE_EXPAT -c ogrgpxlayer.cpp
-DDLL_EXPORT -DPIC -o ../o/.libs/ogrgpxlayer.o
ogrgpxlayer.cpp: In function 'char* OGRGPX_GetUTF8String(const char*)':
ogrgpxlayer.cpp:1088: error: 'CPLIsUTF8' was not declared in this scope
ogrgpxlayer.cpp:1106: error: 'CPLForceToASCII' was not declared in this
scope
make[3]: *** [../o/ogrgpxlayer.lo] Error 1
I can't see why CPLIsUTF8 is not being picked up from port/cpl_strings.h.
These are recent changes - has anyone else seen the problem?
Motivation - trying to build an rgdal Windows binary using MSYS in the
usual way to let R/SAGA people try out the GDAL SAGA driver. I could drop
expat for now, but I'll need it again when 1.7.0 is released for GPX and
KML.
Grateful for pointers,
Roger
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
