[Gdal-dev] gdal build failure on SUSE LINUX Enterprise Server 10
Alans
alan.stratford at goodrich.com
Thu Dec 10 10:15:25 EST 2009
Frank Warmerdam wrote:
> This is very odd - I've never seen something quite like it.
> One work around would likely be to configure GDAL --without-libtool. I
> wonder if 1.6.3 got released with an unstable libtool version. Could you
> try 1.6.2 on this system and see if that works?
Thanks Frank,
I will try 1.6.2 and get back to you.
Alan
View this message in context: http://n2.nabble.com/gdal-build-failure-on-SUSE-LINUX-Enterprise-Server-10-tp4145777p4145859.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
