[Gdal-dev] gdal build failure on SUSE LINUX Enterprise Server 10
pcreso at pcreso.com
Thu Dec 10 10:44:20 EST 2009
Hi Alan,
This doesn't fix you problem specifically, but may help.
We usually use the packages from the OpenSuse Geo repository, which has SLES specific builds available. (We are using SLES for most Linux servers in our organisation)
See: http://download.opensuse.org/repositories/Application:/Geo/SLE_10/
This saves either compiling from source or building our own SLES packages.
If we need something, like a new version which is not there, I have found the repository maintainers are very responsive to requests to provide updates & new packages.
While I like OpenSuse anyway, as a FOSS GIS "specialist" the Geo repository is the main reason I primarily use OpenSuse as a Linux distro.
Cheers,
Brent Wood
--- On Fri, 12/11/09, Alans <alan.stratford at goodrich.com> wrote:
> From: Alans <alan.stratford at goodrich.com>
> Subject: Re: [Gdal-dev] gdal build failure on SUSE LINUX Enterprise Server 10
> To: gdal-dev at lists.osgeo.org
> Date: Friday, December 11, 2009, 4:15 AM
> Frank Warmerdam wrote:
> > This is very odd - I've never seen something quite
> like it.
> > One work around would likely be to configure GDAL
> --without-libtool. I
> > wonder if 1.6.3 got released with an unstable libtool
> version. Could you
> > try 1.6.2 on this system and see if that works?
> Thanks Frank,
> I will try 1.6.2 and get back to you.
> Alan
> View this message in context: http://n2.nabble.com/gdal-build-failure-on-SUSE-LINUX-Enterprise-Server-10-tp4145777p4145859.html
> Sent from the GDAL - Dev mailing list archive at
> Nabble.com.
> gdal-dev mailing list
