[gdal-dev] RasterIO slower on Windows
Even Rouault
even.rouault at mines-paris.org
Fri Dec 11 13:41:28 EST 2009
Adam,
I assume that you're testing on the same machine. Such difference is not
expected. Do you see that slowdown with different GDAL drivers or just
for one in particular (which one?)
Windows builds are able to use overviews. But are you speaking about
internal GeoTIFF overviews or about external overviews (.ovr files) ?
Even
Adam Kubach a écrit :
> Hi,
> It appears that my calls to RasterIO are about 10 times slower on
> Windows than Linux when reading from the same dataset. I wouldn't
> think that there would be a noticeable difference. Has anyone else
> seen this? Is it possible that the overviews aren't being used on
> Windows? Is there anyway I can verify that they are being used (Other
> than a debugger)?
> Thanks,
> Adam
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
