[gdal-dev] natgrids option in /usr/share/proj/epsg entry?
Sven Geggus
lists at fuchsschwanzdomain.de
Sat Dec 12 08:39:10 EST 2009
Dear List,
I have a problem which is related to the one I had in summer.
While it works fine using the +nadgrids option on the command line of
gdal tools (with +wktext added) it does not seem to work when added
ad an entry to /usr/share/proj/epsg.
The nadgrids Option is ignored in this case which I can verify using
strace.
So what would I need to add to /usr/share/proj/epsg to get the
behaviour of the following command line argument:
'+proj=tmerc +lat_0=0 +lon_0=12 +x_0=4500000 +y_0=0 +k=1.000000 +ellps=bessel +units=m +nadgrids=/usr/share/proj/BETA2007.gsb +wktext'
Here is the entry which does not work:
# DHDN / Gauss-Kruger zone 4
<31468> +proj=tmerc +lat_0=0 +lon_0=12 +x_0=4500000 +y_0=0 +k=1.000000 +ellps=bessel +units=m +nadgrids=/usr/share/proj/BETA2007.gsb +no_defs <>
Sven
"Der wichtigste Aspekt, den Sie vor der Entscheidung für ein Open
Source-Betriebssystem bedenken sollten, ist, dass Sie kein
Windows-Betriebssystem erhalten." (von http://www.dell.de/ubuntu)
/me is giggls at ircnet, http://sven.gegg.us/ on the Web
