[gdal-dev] How to set BoundingBox within a shapefile using OGR
Pythons bindings
Daniele Romagnoli
daniele.romagnoli at geo-solutions.it
Wed Dec 16 12:50:59 EST 2009
Hi list,
I'm creating a shapefile using the OGR python bindings. (from the 1.6.1
installer)
I have some issues in creating the boundingBox for it.
This is a snippet of the code I'm using:
from osgeo import ogr
from osgeo import osr
northings_llc = dd['northings_llc']
northings_urc = dd['northings_urc']
eastings_llc = dd['eastings_llc']
eastings_urc = dd['eastings_urc']
t_srs = osr.SpatialReference()
t_srs.SetFromUserInput('EPSG:32632')
drv = ogr.GetDriverByName('ESRI Shapefile')
ds = drv.CreateDataSource(fileout)
x0, y0, x1, y1 = str(eastings_llc[0][0]), str(northings_llc[0][0]),
str(eastings_urc[0][0]), str(northings_urc[0][0])
layer = ds.CreateLayer(ds.GetName(), geom_type = ogr.wkbPolygon, srs =
t_srs)
geom = ogr.Geometry(type = layer.GetLayerDefn().GetGeomType())
geom.AssignSpatialReference(t_srs)
wkt = 'POLYGON('+x0+','+y0+','+ x0+','+ y1+','+ x1+',' +y1+','+ x1+','
+y0+','+ x0+',' +y0+')'
print(wkt)
geom.importFromWkt(wkt)
When running, I get this output:
POLYGON(602759.984846,4739727.96408,602759.984846,4739720.3473,602760.45247,4739720.3473,602760.45247,4739727.96408,602759.984846,4739727.96408)
File "prova.py", line 42, in <module>
File "c:\python26\lib\site-packages\osgeo\ogr.py", line 2672, in <lambda>
__getattr__ = lambda self, name: _swig_getattr(self, Geometry, name)
File "c:\python26\lib\site-packages\osgeo\ogr.py", line 34, in
_swig_getattr
raise AttributeError,name
AttributeError: importFromWkt
Indeed, looking at the ogr.py there is no "importFromWkt" in the Geometry
definition.
How can I set the bounding box within the geometry?
Any help would be greatly appreciated.
Best Regards,
Daniele
Eng. Daniele Romagnoli
Software Engineer
GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
Italy
phone: +39 0584983027
fax: +39 0584983027
mob: +39 328 0559267
http://www.geo-solutions.it
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091216/baacc4a4/attachment.html
