[gdal-dev] ESRI arcgis 9.x
Jérôme - GeoRezo.net
jerome at georezo.net
Thu Dec 17 17:37:47 EST 2009
Hello,
However, you can repair shapefiles. ESRI site give several tools, one :
http://arcscripts.esri.com/details.asp?dbid=13733
After repairing, you will read your ESRI files with ogr how you want.
Thanks
Jérôme Cuinet
Selon Frank Warmerdam <warmerdam at pobox.com>:
> Donnet , Sebastien wrote:
> > Hi,
> > sorry in advance if it's a stupid (or already well covered) question,
> > but today I tried to read a shapefile coming from, I believe, ArcGIS 9.2
> > and run out into trouble:
> > ERROR 4: Unable to open Bedrock.shx or Bedrock.SHX.
> > FAILURE:
> > Unable to open datasource `Bedrock.shp' with the following drivers.
> > instead of an shx I have an sbn and an sbx
> > My version of ogr/gdal: from FWTools226.exe
> > (I'm on windows)
> > thanks in advance for any hints.
> Sebastien,
> OGR cannot currently read shapefiles without a .shx file. The .sbn and
> .sbx files are spatial indexes, and not used by GDAL. The .shx file is
> basically a "shape id to file offset" index.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
