[gdal-dev] Setting nodata tag with Python API
Thu Dec 31 11:27:46 EST 2009
Roger André wrote:
> Hi All,
> I'm using the Python API to build some GeoTIFFs and would like to set
> the nodata value to -9999 at creation time.  How do I do that?  Below
> is a sample of my code
>   def makeRaster(self):
>     out_drv = gdal.GetDriverByName('GTiff')
>     out_ds = out_drv.Create(self.raster_name, 4320, 2160 , 1, gdal.GDT_Float32)
>     out_ds.SetGeoTransform([-180, 0.0833330, 0, 90, 0, -0.0833330])
>     out_band = numpy.zeros([out_ds.RasterYSize, out_ds.RasterXSize])
>     for iY in range(out_ds.RasterYSize):
>       for iX in range(out_ds.RasterXSize):
>         alloc_key = self.makeAllocKey(iY + 1, iX + 1)
>         pixel_value = self.checkPixel(alloc_key)
>         out_band[iY][iX] = pixel_value
>     out_ds.GetRasterBand(1).WriteArray(out_band)
>     out_ds = None
Roger,
Try adding:
   out_ds.GetRasterBand(1).SetNoDataValue( -9999 )
after the WriteArray() (or anywhere after the Create() call I suppose).
Best regards,
