[Gdal-dev] transform point problem using gdal 1.5 with osr
Johan_L johanlahti at gmail.com
Tue Feb 3 04:20:55 EST 2009
I'm having the same problem. I tried another way according to one example I
found, which doesn't work either:
from osgeo import ogr, osr
# Get the geometry object
ds = ogr.Open("inFile.shp")
layer = ds.GetLayer()
feature = layer.GetNextFeature()
geom = feature.GetGeometryRef()
# Get the coordinate systems and transform
inSR = osr.SpatialReference()
inSR.GetGeometryRef() # this is WGS84
outSR = osr.SpatialReference()
outSR.ImportFromEPSG(2400) # RT90 (Sweden)
coordTrans = osr.CoordinateTransformation(inSR, outSR)
geom.Transform(coordTrans)
Results in the following error message:
TypeError: in method 'Geometry_Transform', argument 2 of type
'OSRCoordinateTransformationShadow *'
prairie Last wrote:
> I am trying to tranform one coordinate system to another (wgs84 to utm).
> Found one example on the internet (adapted a little). It got an error when
> I
> try to run the program. Since I am new to GDAL, I cannot figure out how to
> correct this. Please see the following program. I also tried to add one
> more
> value to "res.ct.TransformPoint(lon, lat)", but it did not solve the
> problem.  Any help or hint appreciated. I also attach the error to the
> end.
> from osgeo import osr
> import math
> import pyproj
> def UTMZone(lon, lat):
>     return int((lon + 180) / 6) + 1
> if __name__ == '__main__':
>     lat = 41.395304
>     lon = 73.310067
>     wgs84 = osr.SpatialReference()
>     utm = osr.SpatialReference()
>     wgs84.ImportFromProj4("+proj=latlong +datum=WGS84")
>     utm.ImportFromProj4("+proj=utm +zone="+str(UTMZone(lon,lat))+"
> +datum=WGS84")
>     ct = osr.CoordinateTransformation(wgs84,utm)
>     res= ct.TransformPoint(lon, lat)
>     print res
>  Error Message:
> Traceback (most recent call last):
>   File "C:\Python25\trans.py", line 28, in <module>
>   File "C:\Python25\lib\site-packages\osgeo\osr.py", line 602, in
> TransformPoint
>     return _osr.CoordinateTransformation_TransformPoint(*args)
> NotImplementedError: Wrong number of arguments for overloaded function
> 'CoordinateTransformation_TransformPoint'.
>   Possible C/C++ prototypes are:
>     TransformPoint(double [3])
>     TransformPoint(double [3],double,double,double)
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
View this message in context: http://n2.nabble.com/transform-point-problem-using-gdal-1.5-with-osr-tp2036503p2262370.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
