[gdal-dev] Transformation from WGS84 to Cape Datum
Craig Leat craig.leat at gmail.com
Wed Feb 4 13:19:07 EST 2009
Wesley Roberts:
> I would like to perform a datum transformation from WGS84 to the Cape Datum
> using the clark 1880 spheroid. Is this possible using ogr? I have tried using
> ogr2ogr but have had no luck as I am not sure how to specify the correct
> projection parameters and am not sure if ogr supports the Cape Datum and
See here:
http://article.gmane.org/gmane.comp.gis.proj-4.devel/2188/
Craig
