[Gdal-dev] GDAL - CSharp
Tamas Szekeres szekerest at gmail.com
Wed Feb 11 18:38:17 EST 2009
You should provide further info about your environment:
1. Did you test your app by running from an IDE like VS2005 for example?
2. What version of OS/IIS you intend to use when deploying the application.
You appdir and platform configuration (32/64) may be different depending on
your environment.
For example by using the VS IDE you'd probably use WebDev.WebServer.exe as
the host process which is running against the 32 bit version of the .NET
framework on a 64 bit machine.
You might want to use SysInternals ProcMon.exe to make sure about the
expected locations of the dll files.
Best regards,
Tamas
2009/2/12 Tri <rsosnowski at cableone.net>
> Tamas,
> I'm creating web services.  This is first go on 64 bit machine - plenty of
> 32 bit web services to fall back on.  The problem is I was using FDO which
> as far as I know has only 32 bit compiled code.  So I set the 'Enable 32
> Bit
> Application' to true, published the application, then tried to run from
> localhost.  There were no problems with 64 bit, 32 bit conflicts this way.
> However, I then started getting an error that says:
> System.IO file not found.   I'm not using System.IO file in the web
> service.
> So, I thought I would use your compiled 64 bit GDAL / OGR code to create a
> new web service, but running into previously mentioned problem taking this
> approach.
> Thanks again.....
> Tamas Szekeres wrote:
> > What kind of application you develop  Console/WinForms/ASP.NET ?
> > Wouldn't it be sufficient to use 32 bit binaries and compile your app
> with
> > the /platform:x86 option?
> > Best regards,
> > Tamas
> >> Hi Tamas and others - thanks for the help.
> >> By application executing directory - I've copied the files to both the
> >> bin
> >> directory under the project and the obj, Debug directory under the
> >> project.
> >> When I run the application in debug mode, the same problem occurs:
> >> System.TypeInitializationException:   The type initializer for
> >> OSGeo.OGR.Ogr
> >> threw an exception
> >> InnerException:   The type initializer for OSGeo.OGR.OgrPINVOKE threw an
> >> excpetion
> >> I am using the 64 bit compiled code from you on Vista 64 bit machine.
> >> Any more ideas?  Thanks.....
> >> > Hi,
> >> > You might have to copy all of the dll-s (*_csharp.dll, *_wrap.dll,
> >> > gdal16.dll, proj.dll etc.) to the application executing directory.
> >> > Best regards,
> >> > Tamas
> >> > 2009/2/11 Tri <rsosnowski at cableone.net>
> >> >> Can't get GDAL / OGR to work with CSharp.  Using the CSharp dlls, I
> >> keep
> >> >> getting exceptions like:
> >> >> OgrPINVOKE, threw an exception.
> >> >> TO TRY TO GET TO WORK I DID:
> >> >> - Copied the csharp dlls into project,
> >> >> - Created a reference to the dlls.
> >> >> What am I doing wrong?
> >> >> View this message in context:
> >> >> http://n2.nabble.com/GDAL---CSharp-tp2308674p2308674.html
> >> >> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> >> >> _______________________________________________
> >> >> gdal-dev mailing list
> >> >> gdal-dev at lists.osgeo.org
> >> >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> >> http://n2.nabble.com/GDAL---CSharp-tp2308674p2312047.html
> http://n2.nabble.com/GDAL---CSharp-tp2308674p2312090.html
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090212/451177bf/attachment-0001.html
