[gdal-dev] ARM platform compatibility
Adriano C Naspolini adriano at arvus.com.br
Mon Feb 16 23:22:34 EST 2009
Hi Tom,
I was trying with 1.5.3 (Debian etch, gcc-4.1), now changed to 1.6.0,
but no success.
About 1.5.2 version, didn't work neither.
By default, configuration sets up "msb2lsb" (big-wordian). Forcing the
configuration (changing configure file) to be "lsb2msb" make no
difference (maybe because the problem is exactly there).
The next step I'll do is to apply Etienne's patch manually, because it
became incompatible with newer versions of shpopen.c...
Thanks,
Adriano
Tom Kazimiers escreveu:
> Hi Adriano,
> which version of CGAL did you compile for ARM?
> I use 1.5.2 and reading shapefiles works very well.
> Regards,
> Tom
> Adriano C Naspolini schrieb:
>> Hi,
>> I developed an application and it runs perfectly over X86. However,
>> when i try to run it on ARM it stops reading shapefiles (actually it
>> reads wrong coordinates). I wrote a simple program to tell just the
>> first "point" coordinates.
>> On X86:
>> x=: -53.1275 y= -31.8682
>> On ARM:
>> x=: -1.00226e-13 y= -1.76938e+52
>> Looking for the problem here, i found a thread from Etienne Dube on
>> (2004-04-07 05:12:55 GMT), saying it's a byte ordering problem.
>> "Each 32-bit word in the 64-bit double value is stored little-endian,
>> but the most significative 32-bit word comes last in memory
>> ("big-wordian")."
>> Changing the word-order for the first feature inside the ".shp" ("11
>> 36 3c bd 52 90 4a c0" to "52 90 4a c0 11 36 3c bd") and running it again:
>> under X86:
>> x=: -1.00226e-13 y= -31.8682
>> under ARM
>> x=: -53.1275 y= -1.76938e+52
>> So, clearly, i have the same problem then Etienne. He sent a patch,
>> but didn't made many tests...
>> Is there a "final"solution for the problem? I couldn't see any answer
>> to him.
>> Regards,
>> Adriano
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
