[gdal-dev] modifying HDF4 subdatasets
Andrea Battisti
battisti at actgate.com
Tue Feb 17 14:34:49 EST 2009
Hi all,
is it possible to modify existing HDF4 subdatasets using the GDAL/HDF4
driver ?
I see that the HDF4 driver should support the creation from scratch, but
given a HDF4 file containing a set of subdatasets, would it be possible
to open one of the subdatasets, (over)writing to it using RasterIO() ?
If not, what is the correct way to modify the content of a sub-dataset?
Thanks in advance for any advise.
Best regards,
Andrea Battisti
Applied Coherent Technology Corp.
