[Gdal-dev] GDAL 1.6 Java binding, Windows
Even Rouault even.rouault at mines-paris.org
Thu Feb 19 14:33:05 EST 2009
Hi Matt,
You'll have to build GDAL and the Java bindings from the latest daily snapshot
of the SVN trunk head. You can download the source at
http://download.osgeo.org/gdal/daily/
(download the gdal-svn-trunk*.tar.gz or gdal-svntrunk*.zip at your
convenience)
Thanks
Le Thursday 19 February 2009 20:27:55 Matthew Cole, vous avez écrit :
> Sure, I'd be happy to try them to make sure they don't break anything.
> Where would I get the updated version?
> Matt
> Matthew,
> For the record, I just commited yesterday in GDAL SVN trunk a substantial
> update to the java bindings I was mentionning. Now all necessary typemaps
> have been created, so it looks rather good (no more SWIGTYPE_p_* classes).
> I would be interested in having early feedback from people already using
> the Java bindings to check if I haven't broken existing API. It shouldn't
> hopefully (at least the 2 test applications still run against the
> bindings). It also adds methods with default argument values, for example
> ogr.Open(String filename) in addition to the full ogr.Open(String filename,
> int update). Some facilities that look more java'ish have been added, like
> String Geometry.ExportToWkt(), in addition to the existing int
> Geometry.ExportToWkt(String[] argout), etc. A previous commit already added
> support for progress callbacks in GDAL API.
> Best  regards
