[Gdal-dev] GDAL 1.6 Java binding, Windows
trailcode
trailcode at gmail.com
Sun Feb 22 18:06:08 EST 2009
I got gdal java binding to work with win32. I downloaded the jre from:
http://udig.refractions.net/files/downloads/jre/
And used it to execute my test program. For the java .jar files I am not
using gdal.jar but the jars which come with: imageio-ext
The thing which is strange is if I copy the gdaljni.dll gdal14.dll and other
.dll files from the jdk downloaded above to my project dir and set my
java.library.path to point to them I get the same old unsatisfied link
error. I even tried copying over all .dll files in the JDK tree but got the
same message.
Does anyone have any idea what is going on here?
I would like to create an application distributable via jnlp.
Thanks,
Matthew Tang
View this message in context: http://n2.nabble.com/GDAL-1.6-Java-binding%2C-Windows-tp2299600p2369562.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
