[gdal-dev] MapServer and GDAL daily build Windows binaries
available
Even Rouault
even.rouault at mines-paris.org
Wed Feb 25 18:23:09 EST 2009
Tamas,
this is a very good initiative ! It works pretty well as I've been able to run
the Java GDAL apps from trunk under Wine ! (The apps themselves are not
included in the bin/gdal/java directory of your packages, as they were
missing from the ant build.xml. I've just commited a change in r16417, so
that the .class should be generated in swig/java/build/apps)
wine
~/.wine/c/Program\Files/Java/jre6/bin/java.exe -cp "../../swig/java/apps;./gdal.jar"
gdalinfo byte.tif
(And I also hope we'll see buildbot working again soon.)
Best regards.
Even
Le Wednesday 25 February 2009 22:34:37 Tamas Szekeres, vous avez écrit :
> Hi All,
> I've set up a build server providing daily snapshot builds for various
> compilers/architectures and created a root page containing the links to the
> results (along with the build SDKs have been used for the builds)
> http://vbkto.dyndns.org:1280/sdk/index.html
> You can simply download and use any of the build snapshots to be able to
> obtain the Windows binaries with the recent fixes without requiring to
> compile by yourself. But if you would rather compile by hand (eg for
> debugging purposes) just pick up the SDK packages providing a ready to use
> compile environment for all of those platforms enumerated.
> You may encounter some features missing (like swigpython binaries,
> mapscript-java etc) which are about to be added shortly, after I make sure
> those are working equally well on all platforms. I'll also provide links to
> the corresponding autotest results until the buildbot configuration is not
> resurrected.
> Best regards,
> Tamas
