[gdal-dev] ASCII Rasters and 'null' values in python-gdal
Oz Nahum nahumoz at gmail.com
Thu Feb 26 16:04:51 EST 2009
I have to ascii raster that I created using a text editor:
the first is called raster1.asc and looks like this:
<http://forum.qgis.org/viewtopic.php?f=2&t=4552#>ncols         6
nrows         4
xllcorner     3366820.0000019
yllcorner     5814589.0300007
cellsize      10
NODATA_value  -9999
1 1 1 1 1 1
1 1 1 1 1 1
1 1 1 1 1 1
1 1 1 1 -9999 -9999
The second is called raster2.asc and looks like this:
nrows         4
cellsize      10
NODATA_value  null
1 1 1 1 1 1
1 1 1 1 1 1
1 1 1 1 1 1
1 1 1 1 null null
When I import them into python I find out the lower right corner of the
first raster is not giving the correct value: instead of 'null' qgis
displays the value '31081'.
The other raster is imported correctly and it showing 'null's for the two
last data cells.
>>> dataset = gdal.Open('raster2.asc', GA_ReadOnly)
>>> b = gdal_array.DatasetReadAsArray(dataset)
>>> b
array([[1, 1, 1, 1, 1, 1],
       [1, 1, 1, 1, 1, 1],
       [1, 1, 1, 1, 1, 1],
       [1, 1, 1, 1, 0, 0]], dtype=int16)
>>> dataset = gdal.Open('raster1.asc', GA_ReadOnly)
>>> a = gdal_array.DatasetReadAsArray(dataset)
>>> a
array([[    1,     1,     1,     1,     1,     1],
       [    1,     1,     1,     1, -9999, 31081]], dtype=int16)
So before I go and open a bug, I just wanted to know - what is wrong ? Maybe
it's my system setup ? Maybe i don't write correct ascii rasters ? Also,
another thing I would like to bypass is the fact that 'null' values are
formed as zeros in gdal-numpy - this could lead to error when doing some
raster manipulations. Is there a way to by pass this (besides being
aware...)?
I use Debian Lenny the latest relevant packages from.
Thanks,
Oz N,
Grad Studend,
Universität Tübingen
           Imagine there's no countries
           It isn't hard to do
           Nothing to kill or die for
           And no religion too
           Imagine all the people
           Living life in peace
          You all must read 'The God Delusion'
          http://en.wikipedia.org/wiki/The_God_Delusion
when one person suffers from a delusion it is called insanity. When many
people suffer from a delusion it is called religion."
Robert Pirsig, Zen and the Art of Motorcycle Maintenance
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090226/147dc840/attachment.html
