[gdal-dev] GDAL autotest (nitf_37) causes a crash on Windows
Even Rouault
even.rouault at mines-paris.org
Sat Feb 28 14:04:50 EST 2009
Yes, exactly you need latest trunk to run this test.
Le Saturday 28 February 2009 18:53:30 Frank Warmerdam, vous avez écrit :
> I was seeing a somewhat similar effect with the latest nitf.py and
> a week old FWTools build but when I refreshed from the latest
> GDAL source the problem went away leading me to suspect that the
> test is for a recent fix put in by Even. Are you confident you are
> running the test with the latest source? Perhaps there was a short
> overlap?
