[gdal-dev] GDAL autotest (nitf_37) causes a crash on Windows
Even Rouault
even.rouault at mines-paris.org
Sat Feb 28 14:30:10 EST 2009
Tamas,
Yes, nitf_37 won't work against the stable branch.
Generally speaking, I think you should only run the stable branch with its
autotest in branches/1.6/autotest, and not trunk autotest, as there are new
features and bug fixes that go only in trunk and whose testing against stable
can easily crash. Of course, I could make some conditionnal testing on the
GDAL version to skip that test, but I don't think it's really worse the
effort as similar issues could appear elsewhere in that autotest suite. And
even if you don't get crashes, you'll get lots of failed tests.
Even
Le Saturday 28 February 2009 20:09:12, vous avez écrit :
> I've been running against the stable branch. Is this an issue?
> Best regards,
> Tamas
> 2009/2/28 Even Rouault <even.rouault at mines-paris.org>
> > Yes, exactly you need latest trunk to run this test.
> > Le Saturday 28 February 2009 18:53:30 Frank Warmerdam, vous avez écrit :
> > > I was seeing a somewhat similar effect with the latest nitf.py and
> > > a week old FWTools build but when I refreshed from the latest
> > > GDAL source the problem went away leading me to suspect that the
> > > test is for a recent fix put in by Even. Are you confident you are
> > > running the test with the latest source? Perhaps there was a short
> > > overlap?
