[gdal-dev] help with gdalwarp
Joaquim Luis jluis at ualg.pt
Sun Jan 4 18:05:09 EST 2009
Alex Bernstein wrote:
> On Sun, Jan 4, 2009 at 11:00 PM, Joaquim Luis <jluis at ualg.pt> wrote:
> Joaquim, renaming the world file to NE2_land_only.jgw was one of first
> things I've done, sorry I forgot to mention that. So it's not reason
> for the problems I'm having with reprojection.
> The coordinates in world file are specified in degrees, is this how it
> supposed to be, or do I need to pass any switches to gdalwarp to
> indicate that?
Alex,
Sorry, I don't know. Normally "Lambert Azimuthal Equal Area" should take two
standard parallels, but it makes no difference here. I tried
gdalwarp -s_srs "+proj=eqc +lat_ts=0 +lon_0=0 +datum=WGS84"
-t_srs "+proj=laea +lat_1=20n +lat_2=60n" -co TFW=YES NE2_land_only.jpg NE2_land_only_laea.tif
which reports
Upper Left  (-180.0111111,  89.4085425) (  0d 0'5.82"W,  0d 0'2.91"N)
Lower Left  (-180.0111111, -89.3968263) (  0d 0'5.82"W,  0d 0'2.91"S)
Upper Right ( 179.9964220,  89.4085425) (  0d 0'5.82"E,  0d 0'2.91"N)
Lower Right ( 179.9964220, -89.3968263) (  0d 0'5.82"E,  0d 0'2.91"S)
Center      (  -0.0073446,   0.0058581) (  0d 0'0.00"W,  0d 0'0.00"N)
but the file is not reprojected either.
I don't know if it is related but I found many instances where gdalwarp fails
on global files. I reported that twice, last one on ticket
http://trac.osgeo.org/gdal/ticket/2305
but unfortunately it didn't deserve any attention.
