[gdal-dev] GDAL ReadRaster thread-safe?
Thu Jan 8 12:09:02 EST 2009
Eric Domazlicky wrote:
> I am developing a tiling application and I was hoping to up the speed a
> bit by doing some multithreading. What I want to do is start each of 3
> ReadRaster calls in seperate threads (using BeginInvoke delegates), then
> wait for them to complete and build my RGB image (using EndInvoke). I am
> using the C# wrapper to the GDAL library. This multithreaded approach is
> showing clear signs of race conditions, with some of the channels not
> appearing, random crashes etc. If I ensure each thread completes before
> I go on to read the next Raster Band it works fine.
> Is there anyway to make ReadRaster thread-safe? Maybe by disabling
> caching which I suspect is the problem.
Eric,
GDAL is intended to support multi-threading for the case where each thread
is accessing a distinct dataset object.  It is certainly not safe to have
more than one thread accessing a single dataset object at the same time.
If nothing else, there is generally only one underlying FILE * for accessing
the physical file.
Best regards,
