[gdal-dev] ogr2ogr shape file extent reprojection
Frank Warmerdam
warmerdam at pobox.com
Thu Jan 8 12:59:00 EST 2009
santoshamb wrote:
> At first I used ogr2ogr to convert my data, but eventually I started
> using the .Net ProjNET library. That is when I noticed something
> interesting. When converting LineStrings, ogr2ogr and ProjNet yield
> basically the same results up to 9 or so decimal places which is just
> fine for accuracy. Where I began to see a lot of differences between
> the two was when I looked at the extent fields in the shapefile
> header.
Ben,
To me this suggests that ProjNet may be reprojecting the extents while
ogr2ogr is reprojecting the geometries, and recomputing the extents in the
new coordinate system. I haven't verified ... just a guess.
I do know that ogr2ogr recomputes the extents written to a shapefile based
on the geometry ... extents are not carried along through a translation.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
