[gdal-dev] GDAL ReadRaster thread-safe?
Tamas Szekeres szekerest at gmail.com
Thu Jan 8 16:26:34 EST 2009
Eric,
You could refer to the RasterIO documentation regarding to these parameters:
http://www.gdal.org/classGDALDataset.html#e077c53268d2272eebed10b891a05743
If you provide your source data then I could try reading it into a GDI+
bitmap object.
Best regards,
Tamas
2009/1/8 Eric Domazlicky <edomazlicky at gmail.com>
> This looks like a great way to go but can anyone explain exactly what the
> bandmap and bandspace parameters are? I know BandMap is an array but what is
> it supposed to represent? I want the image data to be read and put into my
> destination buffer in ARGB format, the source data is in RGBA format. I
> tried making an array with elements in order: 4,1,2,3 but the destination
> data is transparent so I'm thinking the alpha value isn't getting read
> right.
> On Wed, Jan 7, 2009 at 4:12 PM, Tamas Szekeres <szekerest at gmail.com>wrote:
>> Eric,
>> The most performant option I'm aware of is reading the dataset directly
>> into a bitmap buffer something like:
>> try
>>         int stride = bitmapData.Stride;
>>         IntPtr buf = bitmapData.Scan0;
>>         ds.ReadRaster(xOff, yOff, width, height, buf, imageWidth,
>> imageHeight, dataType,
>>         channelCount, bandMap, pixelSpace, stride, 1);
>> finally
>>         bitmap.UnlockBits(bitmapData);
>> In this case there's no internal buffers in the marshalling code used by
>> the C# wrappers. The only challenge here is to ensure that the bitmap buffer
>> should have the same structure as the gdal dataset represents. You could
>> refer to the complete example in the C# wrapper for the details:
>> http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/csharp/apps/GDALDatasetRasterIO.cs
>> http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/csharp/apps/GDALReadDirect.cs
>> I don't think if triggering multiple reads for different sections in
>> multiple threads is currently supported by gdal, it might also be driver
>> dependent how the reads are actually implemented by the drivers, however you
>> might anyway try defining separate Dataset objects for the different when
>> performing the read operations, but there might be locks in different places
>> causing the operations to be serialized in effect.
>> Best regards,
>> Tamas
>>>  I am developing a tiling application and I was hoping to up the speed a
>>> bit by doing some multithreading. What I want to do is start each of 3
>>> ReadRaster calls in seperate threads (using BeginInvoke delegates), then
>>> wait for them to complete and build my RGB image (using EndInvoke). I am
>>> using the C# wrapper to the GDAL library. This multithreaded approach is
>>> showing clear signs of race conditions, with some of the channels not
>>> appearing, random crashes etc. If I ensure each thread completes before I go
>>> on to read the next Raster Band it works fine.
>>> Is there anyway to make ReadRaster thread-safe? Maybe by disabling
>>> caching which I suspect is the problem.
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090108/4303b4ed/attachment-0001.html
