[gdal-dev] Unknown file type
Frank Warmerdam
warmerdam at pobox.com
Fri Jan 9 13:45:23 EST 2009
Greg Ederer wrote:
> Metadata:
> AREA_OR_POINT=Area
> Image Structure Metadata:
> INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left ( 0.0, 0.0)
> Lower Left ( 0.0, 801.0)
> Upper Right ( 751.0, 0.0)
> Lower Right ( 751.0, 801.0)
> Center ( 375.5, 400.5)
> Band 1 Block=751x2 Type=Float32, ColorInterp=Gray
> NoData Value=-999
> However, when I attempt to load this GeoTIFF into GeoServer, my ultimate
> goal, I get:
> class org.vfny.geoserver.global.ConfigurationException: Could not obtain
> a reader for the CoverageDataSet. Please check the CoverageDataSet
> configuration!
> I have successfully loaded other GeoTIFFs into GeoServer that were
> prepared by another member of our team from the same raw binary data
> using IDL So, I suspect that there is something amiss with my GeoTIFF.
Greg,
I notice you did not include a GeoTransform tag to indicate the georeferenced
location. Without this you are not getting valid corner coordninates and
this may be what is preventing GeoServer from reading the file.
Keep in mind that the origin in the geotransform should be the top left corner
of the top left pixel treated as an area.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
