[gdal-dev] Unknown file type
Greg Ederer
greg at ergonosis.com
Fri Jan 9 15:31:56 EST 2009
That did the trick. Thanks!
Greg
On Jan 9, 2009, at 12:21 PM, Frank Warmerdam wrote:
> Greg Ederer wrote:
>> Note that the pixel/line coordinates in the above are from
>> (0.0,0.0) at the top left corner of the top left pixel to
>> (width_in_pixels,height_in_pixels) at the bottom right corner of
>> the bottom right pixel. The pixel/line location of the center of
>> the top left pixel would therefore be (0.5,0.5).
>> </end docs>
>> But, I'm still unsure how to compute the required values. The docs
>> don't give units for GT(1) and GT(5), and for GT(0) and GT(3). My
>> data have a resolution of 0.1 deg lat X 0.1 deg lon, and the upper
>> left lat/lon is 40N,20W. Could you give me some pointers on how to
>> compute the transform values?
> Greg,
> The geotransform coordinate system is whatever is defined by the <SRS>
> tag. So in your case I believe long/lat WGS84.
> I imagine your GeoTransform would be:
> -20.05, 0.1, 0.0, 40.05, 0, 0.1
> This is assuming that the upper left corner really reflects the center
> of the top left pixel in which case a half pixel offset is needed.
> I'm
> also assuming north up image orientation.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for
> Rent
