[Gdal-dev] Supressing aux.xml file generation from gdal_translate
Frank Warmerdam
warmerdam at pobox.com
Mon Jan 12 23:26:37 EST 2009
Tim Osborn wrote:
> Is there a way to supress aux.xml file generation when using gdal_translate?
> Thanks.
Tim,
Set the GDAL_PAM_ENABLED configuration variable to the value OFF. The
easiest way to do this is to set it in the environment.
eg.
set GDAL_PAM_ENABLED=NO
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
