[gdal-dev] Re: how to acces to PDS meta data
lidiriel
ludovic.mercier at gmail.com
Wed Jan 14 03:20:49 EST 2009
Thanks for your response. I will look your changeset and try for my
requirements.
On 13 jan, 19:46, Frank Warmerdam <warmer... at pobox.com> wrote:
> Ludovic Mercier wrote:
> > Hi all,
> > I try to use gdal and otb (http://smsc.cnes.fr/PLEIADES/lien3_vm.htm)
> > with pds file.
> > I try to get value associated to a key (meta-data).
> > for an exemple the file : Index of /gdal/data/mc02.img contain :
> > SPACECRAFT_NAME = "MARS GLOBAL SURVEYOR"
> > INSTRUMENT_NAME = "MARS ORBITER CAMERA"
> > INSTRUMENT_ID = "MOC-WA"
> > TARGET_NAME = "MARS"
> > FILTER_NAME = "RED"
> > I would like to access to the key/value FILTER_NAME. But the function
> > GetMetadata return nothing !
> > I look in the source code (file pdsdataset.cpp) and the interresting
> > method is "GetKeyword()" but it is a private method.
> > Is someone have an idea how to get all meta data or specific meta-
> > data ?
> > I think is it impossible in fact.. but perhaps is it possible if i add
> > new functionnality
> > in the pds driver....
> Ludovic,
> You are correct that none of these header fields are currently exposed
> by the PDS (or ISIS2, and ISIS3) drivers as metadata. It would be
> quite easy to modify the driver to transfer specific keywords and their
> associated value to the metadata object, but it is unclear which ones would
> be useful.
> I have gone ahead and added support in the PDS driver to transfer a bunch
> of keywords over. The gdalinfo results now look like:
> Origin = (-10668384.903788566589355,3852176.483988761901855)
> Pixel Size = (926.115274429321289,-926.115274429321289)
> Metadata:
> FILTER_NAME="RED"
> DATA_SET_ID="MGS-M-MOC-4-WAMOS-V1.0"
> PRODUCT_ID="MC02"
> PRODUCER_INSTITUTION_NAME="MALIN SPACE SCIENCE SYSTEMS"
> PRODUCT_TYPE="MOSAIC"
> MISSION_NAME="MARS GLOBAL SURVEYOR"
> SPACECRAFT_NAME="MARS GLOBAL SURVEYOR"
> INSTRUMENT_NAME="MARS ORBITER CAMERA"
> INSTRUMENT_ID="MOC-WA"
> TARGET_NAME="MARS"
> CENTER_FILTER_WAVELENGTH=600.0000
> BANDWIDTH=50.0000
> PRODUCT_CREATION_TIME=2001-11-28T00:00:00
> NOTE="GEODESY CAMPAIGN MOSAIC"
> Corner Coordinates:
> The new support is only in trunk and new keywords can be added quite
> easily.
> http://trac.osgeo.org/gdal/changeset/16077
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmer... at pobox.com
> light and sound - activate the windows |http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> gdal-dev mailing list
> gdal-... at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/gdal-dev
