[gdal-dev] convert 2 shapefiles to a single GPX?
Duarte Carreira
DCarreira at edia.pt
Thu Jan 15 06:03:27 EST 2009
Maybe the same approach can be used with 2 gpx files? That would be very good. I cannot merge 2 shapefiles with different geometry types. I could convert line shape>gpx1 and point shape->gpx2 and then merge gpx2+gpx2->gpx3...
Thanks,
Duarte
De: Stefan Keller [mailto:sfkeller at gmail.com]
Enviada: quarta-feira, 14 de Janeiro de 2009 22:40
Para: Jean-Claude Repetto
Cc: Duarte Carreira; gdal-dev at lists.osgeo.org
Assunto: Re: [gdal-dev] convert 2 shapefiles to a single GPX?
A merge of two shapefiles 'file1.shp' and 'file2.shp' into a new file 'file_merged.shp' is performed like this (See http://www.gdal.org/ogr/drv_shapefile.html):
% ogr2ogr file_merged.shp file1.shp
% ogr2ogr -update -append file_merged.shp file2.shp -nln file_merged
Then convert to GPX:
% ogr2ogr -f "GPX" out.gpx file_merged.shp
Stefan
http://geoconverter.hsr.ch<http://geoconverter.hsr.ch/>
2009/1/14 Jean-Claude Repetto <jrepetto at free.fr<mailto:jrepetto at free.fr>>
Duarte Carreira a écrit :
Can OGR convert 2 shapefiles to a single GPX?
The objective is to add tracks from a line shapefile and waypoints from a point shapefile...
Hello,
I don't know the answer to your question, but since GPX files are text files, it is very easy to merge two GPX files with a text editor.
HTH !
Jean-Claude
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090115/8c68aeaa/attachment-0001.html
