[gdal-dev] Writing a Tiff
Henning Bredel
henning.bredel at uni-muenster.de
Fri Jan 16 04:27:29 EST 2009
On Thu, 2009-01-15 at 16:57 -0500, Frank Warmerdam wrote:
> > bm.writeTiff <- function(bm,filename) {
> > # GTiff ist standard but show it here, though
> > driver <- new('GDALDriver', 'GTiff')
> > t <- new("GDALTransientDataset",driver,nrow(bm),ncol(bm),
> > type="Int32")
> > for (row in 1:nrow(bm)-1) {
> > putRasterData(t,bm[row,1:(ncol(bm)-1)],offset=c(row,1))
> > saveDataset(t,filename)
> > closeDataset(t)
> Henning,
> I am embarrassed to admit I don't even know what language the above is!
> Perl? Ruby?
ups .. sorry, I was on the R-sig mailinglist before, so I forget to
point the language out explicitely. It's R -- I'm using GDAL with a
wrapper package called `rgdal' (Roger Bivand is involved in its
development).
> Normally there is a function to be called to register all the drivers
> with the drivermanager instance. I think all the swig bindings call
> this automatically at load time.
> Then you could normally call GetDriverByName() in the gdal "module" however
> that gets bound into your language.
Well, rgdal offers also a `getGDALDriverByName() method. The output
says that there is GeoTiff creation support.
> In Python the above would be something like:
> driver = gdal.GetDriverByName('GTiff')
> dataset = driver.Create('file.tif', rows, columns, bands, gdal.Int32, None )
> The main point I want to make is you don't actually create a driver object.
> You just get a reference to an existing one from the driver manager which
> is usually hidden by the global GetDriverByName() function
> (GDALGetDriverByName() in C).
I have read a satellite image into a matrix and now I would like
to write it into an image file again (maybe this sounds strange.
If you are interested in the background, I could tell ..).
The thing is, that I want to write into another file format than
the file I have read in, so how could I get the driver, if not
creating a new one?
My first try to write a GTiff with
type="Int32")
closeDataset(
runs into the error (after approx. 30 sec.)
Wrong "StripByteCounts" field, ignoring and calculating from imagelength
What does this error mean??
Another strange thing is, that there is no GTiff support after
that error anymore! The 2nd call of `getGDALDriverNames()' out-
put is missing the GTiff entry at all. Could this be a GDAL
error or do I have to ask at the RGDAL mailinglist as well?
Thx for your help
Henning
. . . no signature
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090116/240c6ec3/attachment.bin
